Мнениеот TT » 10.01.2012 12:14
Нов процес за производство на Фотоволтаични модули
Fraunhofer-Institut für Solare Energiesysteme ISE
Jan 04, 2012
New process for PV module production. TPedge module successfully completes mechanical load test
http://www.ise.fraunhofer.de/en/press-a ... mit-erfolg
Cost reductions in module production with TPedge
The TPedge module is a joint development by Fraunhofer ISE in Freiburg and the Bystronic glass Group on the basis of a Fraunhofer patent. The wafer-based solar module can be produced much quicker and less expensively than standard wafer modules. The time and cost savings are a consequence of a simplified modular structure and a completely innovative production technology. "The cell array is locally fixed between two glass plates", says Dr. Harry Wirth, Head of Group Photovoltaic Modules, Systems and Reliability at Fraunhofer ISE. "The utilisation of foils and the associated laminating are not necessary." The edge sealing of the TPedge module is carried out via the application of the thermoplastic material TPS® at 130°C, even an additional aluminium frame is not necessary. Tobias Neff, Solar Product Manager at Bystronic glass explains: "The TPedge technology reduces the costs of the module production by 30 to 40 percent - at an aspired cycle time of 45 seconds per module line. As a result, the overall costs of a PV module can - depending upon the cost proportion of the solar cells - be reduced by approximately 14 percent."
http://www.bystronic-glass.com/global/c ... geTest.php
TPedge MechLast PI 0112.jpg (72.88 KiB) Прегледано 7395 пъти
Мнениеот TT » 10.01.2012 12:42
Банките дестабилизираха икономиката, като надуваха кредита, а сега - като го свиват и оскъпяват
09:00 | 10.01.2012
Цитат:
Банковата система у нас ще е стабилна, докато е ликвидна, т.е. докато парите, които влизат в банките, са повече от парите, които излизат. И в този смисъл е много полезно да не се признават истинските загуби, които се крият в баланса на банките. Ако банките провизират незабавно всичките си несъбираеми кредити, възможно е да се окаже, че цялата банковата система у нас работи без капитал - плува със свалени гащи.
http://www.mediapool.bg/банките-дестабилизираха-икономиката-като-надуваха-кредита-а-сега---като-го-свиват-и-оскъпяват-news188264.html
КОМИСИЯ ПО ИКОНОМИЧЕСКАТА ПОЛИТИКА, ЕНЕРГЕТИКА И ТУРИЗЪМ
Мнениеот pmihailova » 11.01.2012 17:45
http://www.parliament.bg/bg/parliamenta ... no/ID/1941
РУМЕН ОВЧАРОВ: Въпросът е принципен. Не е въпрос да се изброят няколко обекта, които ползват местни, собствени енергийни ресурси. Въпросът е да се отбележи важността на пълноценното използване на местните или собствените енергийни ресурси при осигуряване на националната сигурност. Защото те в този смисъл имат голямо значение. Струва ми се в такъв документ да се пропусне този елемент ще бъде просто пропуск.
ИВАН ИВАНОВ: Аз искам да подкрепя тази теза, защото действително важния елемент за енергийната сигурност е в максимална степен да се осигури енергийна независимост. Енергийната независимост означава намаляване на зависимостта от внос на енергийни суровини, нещо което между другото тук специално е отбелязано, че това е един рисков елемент за нашата национална сигурност. И то още в първите страници на Стратегията, че това всъщност налага да се работи върху енергийната стратегия по причина, че високата зависимост от енергийни ресурси, пропуснато е "външни енергийни ресурси", създава уязвимост. Тази уязвимост може да се намали, ако наистина беше включен един абзац, в който да се каже, че рационалното и пълноценно използване на местните енергийни суровини, Марица-изток е безспорно един много сериозен сектор на местни енергийни суровини, повишава сигурността и енергийната независимост на страната. Затова подкрепям, че ако има все още възможност един такъв абзац от три, четири реда е напълно достатъчен, но ще даде една по-голяма пълнота на въпроса за енергийната сигурност.
БЛЯ БЛЯ БЛЯ!!!!!!!!!
pmihailova
Мнениеот ivo1009 » 11.01.2012 18:33
"Енергийната Независимост" явно е една от най-любимите теми на всички политически партий не само у нас а и в света, за да създават впечатление в обществото че "уж" се занимават със сериозни теми. Днес четох, че първи измислили тази идея щастските политици и така от 150 години всяко правителство като основен приоритет в изборната си кампания залагало превръщането на щатската икономика в "енергийно независима".
Така като гледам явно и наще момчета не остават назад от тази идея а и как иначе като те всичките или са работили в САЩ или приемат съвети от техния посланик у нас!
ivo1009
Re: КОМИСИЯ ПО ИКОНОМИЧЕСКАТА ПОЛИТИКА, ЕНЕРГЕТИКА И ТУРИЗЪМ
Мнениеот TT » 11.01.2012 22:32
pmihailova написа:http://www.parliament.bg/bg/parliamentarycommittees/members/224/steno/ID/1941
Не разбирам какво общо има поста ти от днес 11.01.2012 с четенето на поправките в закона за ВЕИ от днес, та ти даваш линк към Комисия по икономическата политика, енергетика и туризъм
от дата 12/01/2011 не си ли малко закъсняла с 1 година ???
Мнениеот pmihailova » 12.01.2012 09:16
TT написа:
И 100 години да минат, все същите празни приказки!!!!!!!1
pmihailova
МОНИТОР- Спекула с проекти за ток от вятър
Мнениеот pmihailova » 12.01.2012 09:18
http://www.monitor.bg/article?id=321766
Близо половината от проектите за централи, произвеждащи ток от възобновяеми източници, са спекулативни. Това стана ясно по време на обсъждането на промените в Закона за енергията от възобновяеми източници. Те бяха приети вчера на първо четене от депутатите в комисията по икономика и енергетика.
Според данни на икономическото министерство преди влизането в сила на закона през май 2011 г. са били сключени предварителни и окончателни договори за присъединяване към мрежата на над 7000 мвт "зелени" централи. Към днешна дата те вече са за около 4000 мвт. Както е известно, с новия закон инвеститорите бяха длъжни да гарантират пред НЕК, че действително ще изградят централите си. Това се налага, защото електрическата компания трябва да вложи стотици милиони в разширението на елмрежата, за да може да ги присъедини. За целта със закона беше въведено задължението в НЕК да се внася
аванс за присъединяване от 50 000 лв. за всеки мегават
на планираната централа.
Според зам.-министъра на икономиката и енергетиката Делян Добрев Законът за енергията от възобновяеми източници е отсял спекулативните проекти. Със сигурност още едно такова отсяване ще се случи и след приемането на поправките в него. Причината е, че към момента предварителните и окончателните договори са за 4000 мвт, а въведените в експлоатация централи са с мощност от 700 мвт, или общо за 4700 мвт. В същото време преносната мрежа не може да поеме повече от 2300 мвт. Точно за да не се налага тяхното производство да бъде ограничавано и инвеститорите да губят от това, сега правим измененията в закона, обясни зам.-председателят на ПГ на ГЕРБ Валентин Николов. "Промените са положителни, с тях правителството показва, че мисли напред и действа за решаване на проблемите, които иначе ще се появят след 2 г.", каза зам.-министър Добрев. Впечатление по време на обсъждането на поправките направи, че въпреки редицата изказвания на асоциациите, които защитават интересите на фирмите в бранша, този път те бяха далеч по-малко остри и критични от обичайното.
Добрев допусна още, че и сега част от проектите на етап предварителен договор са спекулативни. Те са за 3000 мвт. Основание да се смята това е, че
инвеститори масово не са внесли в НЕК пари в брой
за да гарантират реализацията им, а са предоставили само банкова гаранция. Три месеца след промените в закона ще стане ясно какъв е делът на спекулативните проекти от тези 3000 мвт, каза Добрев.
По информация на "Монитор" банковите гаранции, внесени в НЕК от ВЕИ инвеститори, са за 100 млн. лв., а в брой - едва 3 млн. лв. "Не знам каква е конкретната сума, но знам, че по-голямата част от авансите за присъединяване са под формата на банкови гаранции", потвърди депутатът от ГЕРБ Валентин Николов.
Основните промени
Преференциалната цена за тока от ВЕИ ще се получава, когато централата вземе Акт 16, сега това става на акт 15.
Ако се строи на етапи, за всеки етап ще се определя различна цена.
Електроенергийният системен оператор ще дава точни дати за присъединяване на всяка централа.
pmihailova
Мнениеот pmihailova » 12.01.2012 10:54
http://www.capital.bg/biznes/kompanii/2 ... ref=novo24
Три консорциума с преобладаващо френско участие кандидатстват за изграждане на първите морски вятърни централи на Франция, съобщи Reuters. Страната се опитва да намали зависимостта си от ядрената енергия и до 2020 г. да покрие 23% от енергийните си нужди със възобновяеми източници.
Обединенията, в които участват GDF Suez, EDF Energies Nouvelles и испанската Iberdrola, искат дялове в пет централи по бреговете на Нормандия и Бретан, които по план ще разполагат с общо 600 перки и 3 гигавата мощност. Очаква се първата фаза на инициатива за въвеждане на вятърна енергия от открито море да струва около 10 млрд. евро.
В момента Франция развива морски вятърни технологии чрез 5-мегаватовите турбини M5000 на вятърното подделение на държавната Areva. Те са използвани в Северно море. Друга френска компания - инженеринговата Alstom, очаква до 2014 г. да пусне 6-мегаватовия ветрогенератор Haliade.
Консорциумът EDF Energies Nouvelles, в който участва Alstom, залага именно на Haliade. Моделът, чиито диаметър на перките е 153 метра (около половината от височината на Айфеловата кула), е най-голямата офшорна вятърна турбина в света.
"На европейския пазар има място за много повече от две нови френски турбини", коментира вицепрезидентът на Areva Wind Филип Кавафиан. Засега Франция изостава в развитието на соларния и вятърния бизнес спрямо държави като Германия, Испания и Дания.
От Areva и Alstom заявиха, че ако спечелят две или три от общо петте тръжни процедури, ще построят заводи, създавайки хиляди работни места. Така те ще могат да изнасят турбини за Великобритания, която сега е най-големият пазар на офшорни технологии.
Париж обяви търговете миналия юли, а през април ще обяви още конкурси по втората фаза на грандиозния проект. По време на втория етап инсталираният капацитет трябва да се удвои до 6 гигагавата, като за целта до 2020 г. инвестициите ще се увеличат до 20 млрд. евро.
До 2020 г. се очаква общата инсталирана мощност на крайбрежните вятърни паркове в Европа да достигне 40 гигавата, показва доклад от миналия ноември на Европейската ветроенергийна асоциация (EWEA). За сравнение в края на 2010 г. са монтирани по-малко от 3 гигавата.
pmihailova
Мнениеот petyostoev » 12.01.2012 11:35
"Държавата рязко скъсява пътя до европарите, но от 2014 г."
http://www.segabg.com/article.php?id=584733
"Недосегаеми чиновници бранят европарите"
http://www.monitor.bg/article?id=321865
Премиерът възмутен, че чуждите компании искат да инвестират
Мнениеот Vandal » 12.01.2012 19:27
Премиерът възмутен, че чуждите компании искат да инвестират в зелена енергия
Премиерът Бойко Борисов се накара в понеделник на инвеститорите, които искат да влагат средства в зелена енергия. По време на дискусия с представители на Американската търговска камара в България Борисов обясни, че неслучайно всички големи компании се насочват към производството на зелена енергия, тъй като тя се изкупува по 580 лева за мегаватчас, докато тази от АЕЦ "Козлодуй" - по 42 лева за мегаватчас.
"Не искам българите да плащат скъпа енергия от възобновяеми енергийни източници. Да си знаем възможностите и да спрете да притискате и ДКЕВР, и министрите в тази посока. Аз съм този, който не желае българският гражданин да плаща скъпа енергия", заяви Борисов, отбелязвайки, че се принуждава да обяснява той темата, тъй като министърът на икономиката и енергетиката Трайчо Трайков е по-възпитан.
Той посочи, че в момента страната няма да присъединява към енергосистемата на ветрогенераторни и соларни паркове, защото сега те са скъпи.
"Поставили сме си за цел до 2020 година да има 20 процента дял от електроенергия от ВЕИ източници и ще я постигнем. Интересът на българския гражданин е да не му се вдига непрекъснато цената на тока заради скъпата зелена енергия и това, че имаме срок до 2020 г. да го направим, когато технологиите сигурно ще станат по-евтини, отстоява интереса на българския гражданин. Искаме елементите за тези паркове да са по-евтини и да се произвеждат в България, за да създават работни места", заяви Бойко Борисов.
mediapool.bg/
Мнениеот joro76 » 12.01.2012 21:42
Тоя човек как се не спря да става смешен и да помисли това (да останат парите в България )как да се случи??? ужас мен !!!!
joro76
Бойко възмутен ?
Мнениеот ivo1009 » 13.01.2012 00:56
Бойко бил възмутен а в същото време Цветелина и Цецко се скъсаха да строят Вятърни и соларниа паркове!
ivo1009
ЕВН България договори 378 MW мощности с ВЕИ
Мнениеот ivo1009 » 13.01.2012 10:42
ЕВН България има потвърдени договори за производствени мощности за електроенергия от възобновяеми енергийни източници (ВЕИ) за общо 378 MW. Това съобщи Илина Стефанова, директор в "Регулационен мениджмънт" в компанията.
Въпросните производствени мощности обхващат общо 486 договора, които бяха потвърдени след влизането в сила на Закона за ВЕИ през 2011 г. От въпросните мощности 271 MW са за ток от слънце, 63 MW - за ток от биомаса и биогаз, 25 MW - за ток от вятър и 19 MW - за ток от мини ВЕЦ.
От компанията посочиха, че до една година от потвърждаването на договорите, по закон фирмите трябва да си осигурят строителни и други разрешителни за новите мощности и да сключат договор с електроразпределителното дружество, което снабдява с ток Пловдив и югоизточна България.
Инсталираните мощности за ток от ВЕИ на посочената територия досега са общо 75 MW.
До края на февруари, пак съгласно закона, ЕРП-тата трябва да дадат информация в НЕК за възможностите си за присъединяване на нови мощности за производство на ток от ВЕИ за периода 1 юли 2012 - 1 юли 2013 г.
Окончателните капацитети ще бъдат определени от ДКЕВР, като се имат предвид и възможностите на НЕК.
Относно промени във влезлия в сила едва от няколко месеца закон за ВЕИ, Гочо Чемширев, председател на УС на ЕВН България Електроразпределение, коментира за Investor.bg, че промените, които предстои да бъдат гледани в парламента, са основно в две направления.
Първо, цената на тока от новите съоръжения с ВЕИ се предвижда да се определя към момента на получаването на т.нар. Акт 16, т.е. при влизането им в експлоатация, а не както досега - при получаването на Акт 15.
Това се прави, тъй като от една страна влизането в експлоатация може да закъснее с повече от година, а от друга - за всяка година ДКЕВР определя нови преференциални цени за тока от ВЕИ, които обикновено са по-ниски от тези от предходната година.
Второ, предвижда се, когато даден обект за производство на електроенергия от вятър или слънце влиза на етапи в експлоатация, то цената на произвеждания ток да се определя поетапно по действащата в момента цена за изкупуване, определена от ДКЕВР.
ivo1009
Мнениеот petyostoev » 13.01.2012 20:15
"ВЕИ енергията в САЩ превиши дела на атомната"
http://insmarket.bg/news/?cat=news&cat_ ... _id=115128
"Когато фактите говорят и боговете мълчат."?????????
