от solarcenter » 31.05.2011 23:03
			Ето това колеги , проучваме , ама явно от толкова ВЕИ people тук и над 80 клика по темата няма отговор за цена $ $ $ ... ?!
First of all,as describe energy developments. Bulgaria is blessed with nature and is rich in renewable energy. Above all,  is rich in geothermal resources, and hot springs as well. Therefore, we consider the geothermal resources to be the one favorable candidate for renewable energy generation. It is possible that among the geothermal energies the hot spring water of 90-100 degrees C can be used for electric energy. Then, the first proposal is "Hot-Spring-water Thermal Energy Conversion." HSWTEC  is a power generating system which uses the high temperature of deep spring hot water and the low temperature of ground water, or low boiling temperature substances such as ammonia. This equipment is already used in Germany/Japan in hot springs. It can be started, after investigating geological hydrologic survey, a power transmission system, the situation of the present hot spring well, etc. ------------------------
